Hi Rahul,
Following is the response, that we we obtained on M66FA-04-STDN. We used the same the example code that was shared by you.
We are having trouble establishing connection to Azure cloud. Please respond
We are facing issue with this AT command below:
– Send AT:AT+QMTCFG=“SSL”,0,1,2, ret = -1 -->
Following is complete log.
<Network State:cgreg = 5
//<Set PDP context 0
//<Set APN
//<Activate PDP context,ret = 0
<-- Send AT:AT+QSECDEL=“NVRAM:CA0”, ret = -1 -->
<//There is no certificate plz write certificate
certificate write
CONNECT
certificate write
+QSECWRITE: 1282,2835
certificate write
<-- Send AT:AT+QSECWRITE=“NVRAM:CA0”,1282,100, ret = 0 -->
certificate write
CONNECT
certificate write
+QSECWRITE: 1230,44e
certificate write
<-- Send AT:AT+QSECWRITE=“NVRAM:CC0”,1230,100, ret = 0 -->
certificate write
CONNECT
certificate write
+QSECWRITE: 1702,4633
certificate write
<-- Send AT:AT+QSECWRITE=“NVRAM:CK0”,1702,100, ret = 0 -->
<-- Set SSL CERTIFICATE, ret=0 -->
<//Send AT:AT+QSSLCFG=“cacert”,2,“NVRAM:CA0”, ret = 0 -->
<-- Send AT:AT+QSSLCFG=“clientcert”,2,“NVRAM:CC0”, ret = 0 -->
<-- Send AT:AT+QSSLCFG=“clientkey”,2,“NVRAM:CK0”, ret = 0 -->
<-- Set SSL CERTIFICATE cofigure, ret=0 -->
<-- Send AT:AT+QMTCFG=“SSL”,0,1,2, ret = -1 -->
<-- Set SSL CERTIFICATE cofigure, ret=-1 -->
<-- Set SSL CERTIFICATE cofigure ERROR, ret=-1 -->
