we have similar problem like here: CLICK.
If the RSSI is low the modem starts to increase the TX power. This causes voltage drops and modem stops responding. We are not able to do anything else in the term of power supply, so the only way is to limit the maximum TX power.
The question is: how to do it on M66/M65?
Ps. We have checked the command (AT+QNVFR=“/nv/item_files/rfnv/00025076”) from BG96, however it returns an error (+CME ERROR: 100).
Thank you. Best regards.
