hii @rahul.mahakalkar,
thanks for replying,
i downloaded latest firmware and load .cnf file…now all file display and i press on start but
FAIL, ERR_1011_S_COM_PORT_OPEN_FAIL
this error given,
Regards
piyush
this error given,
Regards
piyush
i change baudrate from 460800 to 115200 .. and ON D/L pin then press powerkey on my kit..now upgrade successfully… after that any process i do or not ? now i check on putty with 115200 baudrate but its not display anything on screen..
After flashing f/w you have to restart the module. Open Main COM port in putty and send AT commands it will gives you the response.
You have to send AT commands.
i try to enter AT on putty but it will not respond anything and blank display as it is,also i change baudrate like,9600,115200,19200 but not get any respond on putty.
and when i was upgrade firmware after select FW file ,module type is not displaying on latest Qflash software.
Now M66 module work fine…thanks for support..
regards,
PIYUSHGIRI
Hi People, I have a problem with fw update on the M66 modem. The tool QFLASH works totally fine when we have evaluation board with power buttons. Could you please let me know how update of fw is possible when modem is fitted on small PCBs.
Hi Ankush_Nagaraju:
You can refer to the hardware document in the attachment.Quectel_M66_Hardware_Design_V1.2.pdf (2.5 MB)
You can reserve the following pins:
I read other posts and as advised by @rahul.mahakalkar , I downloaded Qflash4.19 and then downloading worked. Initally I was using QFlash that came with SDK downloaded from quectel site.
Hi.
I need latest firmware for M66 FB.
my module version is: M66FBR03A07
Hi Rahul,
My team is having some 200 M66 FA series they have configured it via Opencpu. Now i want to change the firmware to AT so that i can use this module for PPP connection could u please help me with this. As I’m unable to download the firmware u shared
I’m working on an IoT project using the M66 module and I need the latest firmware (specifically for WebSocket/SSL support). Could you please provide a direct download link for the latest firmware and QFlash tool? Model: M66-FB-04
Thank you so much
The FW has sent to your email, pls check.
I’m working on an IoT project using the M66 module and I need the M66FCR01A02BT Version. Could you please provide a direct download link for firmware ? Model: M66-FB-04
Thank you so much
