LwM2M BG96 problem with connect leshan demo server
Hello, I am using a BG96 module with firmware BG96MAR02A07M1G connected to the NB-IoT network
I am trying to use lwm2m with leshan server, as the example in the lwm2m user guide.
My bootstrap.ini
{"bn":"/0/1/",
	"e":[
		{"n":"0","sv":"coap://leshan.eclipseprojects.io:5683"},
		{"n":"1","bv":false},
		{"n":"2","v":3},
		{"n":"10","v":102
My lwm2m.cfg
APN=iie.iot;
RETRY_TIMEOUT=5;
RETRY_EXPONENT_VAL=2;
MAX_RETRY_TIMEOUT=120;
MAX_NO_RETRIES=5;
ACK_TIMEOUT=10;
REG_RETRY_TIMEOUT=5;
REG_RETRY_EXPONENT=2;
REG_RETRY_MAXTIMEOUT=480;
ROAMING_FEAT=0;
PER_REGSTATUS_FEAT=0;
BATTERY_LEVEL_THRESHOLD=20;
REBOOTSTRAP_REG_FAILS_MAX_NO_ATTEMPTS=2;
CARRIER_TYPE=0;
REG_EP_NAME=4;
BOOTSTRAP_EP_NAME=4;
My carrier_apn_cfg
APN_NAME=iie.iot
APN_CLASS=2
BS_IF_REG_FAILS=0
SHORT_SERVER_ID1=102
When I reboot de module I get this in the debug console:
Net: Net Registered
dss_netapp: DSS_NetApp Registered
atfwd_cli_app: Atfwd_Cli_App Registered
LWM2M_EXT: LWM2M_EXT Registered
Command List:
  Commands:
     1. Help
     2. Exit
  Subgroups:
     3. Net
     4. dss_netapp
     5. atfwd_cli_app
     6. LWM2M_EXT
LWM2M: CLI registered
LWM2M: LWM2M_LOG:Carrier type = 0
LWM2M: LWM2M: REG EP NAME = 4
LWM2M: LWM2M: BOOTSTRAP EP NAME = 4
LWM2M: LWM2M: LWM2M_LOG: bootstrap_name --> urn:imei:862315065959552
LWM2M: State: STATE_REGISTER_REQUIREDLWM2M:
LWM2M: State: STATE_REGISTERING
I never get the LwM2M: State: STATE_READY message, and of course my device does not appear in the server.
I thank you in advance for any help.
pls try by AT command
AT+QLWCFG=“security”,0,100,“coap://leshan.eclipseprojects.io:5683”,0,3
AT+QLWCFG=“server”,0,86400,0,60,60,1,“UQS”
AT+QLWCFG=“epns”,0,“0”,“urn:imei:866349043519358”
AT+QLWCFG=“version”,0
AT+QLWSVC=“reg”
AT+QLWSVC=“uldata”,100,“19/0/0”,10,“68656c6c6f776f726c64”,1,1
