LTE5398-M904 LTE Module EG18EA
@herbert.pan-Q herbert.pan-Q would it be possible to reiceve a version of the firmware without the mentioned not correct mobile operator profile?
Thank you!
@herbert.pan-Q
Dear Herbert Pan @herbert.pan-Q ,
I own an Zyxel LTE 5398 with EG18EA in Germany, AT+QGMR → EG18EAPAR01A08M4G.
Would you please be so kind to send me the upgrade and downgrade files!
I will report Band1 peculiarities from Germany!
Thanks in advance, Chris
Please provide your current firmware version. I hope you can update to the latest version and have a try
AT+QGMR
I have sent the latest firmware to your email, pls check
Hi @herbert.pan-Q @jfrog i actually have the
FIRMWARE rev13
root@LTE5398-M904:~# atcmd ‘AT+QCFG=“band”’
+QCFG: “band”,0xcd3,0x1a0080800d5,0x0
and was able to remove the selection of the band, but is it possible to receive a firmware rev 13 withouth this selection in order to avoid to perform the procedure to login as root and all the other steps? Thank you very much!
Sorry, I didn’t understand your description
Can you send me thelte firmware rev13 WITHOUT the mobile operator profile QMBNCFG: “List”,9,0,0,“Telenor_Norway_Commercial”,0x08014300,201902181? This would be very helpful for who is not able to perform all the necessary steps through ssh.
Thank you!
I think this MBN list is fixed. If you are our enterprise user, I suggest you contact the salesperson who made the purchase and apply for a customized version
You mean that quectel has released the fixed versione of this LTE firmware? It is still rev13 or it became rev14?
