I try to set up the EP06ELA-512-SGA module on a Linux kernel 5.15.
I tried the Quectel EC25-E PCI-e module without any problem (with a new USB device on the system).
With the new EP06ELA-512-SGA module, there is no PCI/USB device detected on the system.
What are the requirements to setup this card on a Linux system?
Never asked about PCI. Please do no use pictures.
How exactly this modem is connected to the host system? Are you using an external USB adapter or the PCIe connector is a part of the host system?
Remove the modem and isolate USB3 pins on it, then put it back with the hope.
I assume that you tested EC25 in the same slot, so you’re confident that USB lines are there.
