Loose antenna connection on RM520N-EU
I have a 5g module where one of the ANT is loose. In other words, when attach the IPEX cable, it immediately comes off.
Is there a way to fix it?
Dear @Traction6596
Is it possible to solder on your side? Or not connect this one?
Please take a picture of your module.
Did it click into place before coming off?
Sometimes considerable force is required on one or more connectors.
But ensure the connector is exactly aligned before applying force. And ensure the force is applied exactly downwards.
Otherwise, modem antenna sockets are easily damaged.
Hi, it doesn’t click.
I think the connection is damaged
See attached pic. I think ANT is damages. Is it possible to solder a new IPEX4 Connector? IPEX4 the correct name?
It certainly is.
Yes, I’ve had a damaged antenna socket on an RM500Q-GL replaced by somebody who has all the equipment needed.
Also known as MHF4.
