I am new to here. I am sorry if I am putting this question under the wrong category.
I want to use LC29HBA with an android tablet. What exactly should I do? Thank you very much!
Do you have the source code of the android table? If you can compile the Android source code you can try the Quectel Android GPS driver.
I don’t have it. Is that mean there is no way to use it with android tablet/phones?
If you cannot modify the Android code yourself, you can only see if this Android tablet can directly read the serial port. You can try some apps that read serial ports. Generally speaking, the default is to read the serial port without permission.
