Hi
I am unable to find the linux driver for Quectel EC25 board on the Quectel Website
Somebody know where I can find it
Thank
rpa
EC25 is supported by standard Linux drivers, there is usually no need to look for it.
hello, what type of driver do you need?
As I understand there are two driver one for the USB and the other for the Quectel board -
Hi @rpa
I send the driver to you by message,pls chk.
ok thank I 'll check and try
Ok after compiling the source code it works. It allows to start the device
The devices driver are in the kernel - this latter has to be recompiled if the usb and device driver not set
The 4G/TE connection works now
Thank you
