Hi Quectel team,
I’m bringing up an EM120R-GL module on an ARM64 (aarch64) platform running Linux kernel 5.10. Sadly the kernel version is fixed and cannot be upgraded.
Could you please share:
The latest Quectel PCIe and USB driver for EM120R-GL that builds on kernel 5.10 / aarch64, and
The QConnectManager (quectel-CM) version that is verified to work with the driver?
Please pick the combination that you currently recommend for this module. I would rather use the pair you know is tested together than guess versions myself.
If available, it would also be very helpful to receive:
a log capture / diagnostic utility for Linux (QLog or equivalent), and
the latest EM120R-GL firmware along with the corresponding Linux firmware update tool (QFirehose / QFlash).
These last two are nice-to-have and not blockers. The driver + QCM pair is what I need first.
Thank you!
jfrog
May 18, 2026, 5:21pm
2
Do you see the modem on either bus ?
Start from checking with :
lsusb
lspci
Also looking for the latest module firmware for this:
EM120R-GL
FW: EM120RGLAPR02A09M4G
Driver: mhi-pci-generic
Sorry for late! Here’s what I got from lspci -vvv
0004:01:00.0 Unassigned class [ff00]: Device 1eac:1001
Subsystem: Device 1eac:2001
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Region 0: Memory at 1740000000 (64-bit, non-prefetchable) [disabled] [size=4K]
Region 2: Memory at 1740001000 (64-bit, non-prefetchable) [disabled] [size=4K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/32 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <4us, L1 <64us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s (ok), Width x1 (ok)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, NROPrPrP-, LTR+
10BitTagComp-, 10BitTagReq-, OBFF Not Supported, ExtFmt-, EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS-, TPHComp+, ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled
AtomicOpsCtl: ReqEn-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
Capabilities: [148 v1] Transaction Processing Hints
No steering table available
Capabilities: [1d4 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [1dc v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=70us PortTPowerOnTime=0us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=0us LTR1.2_Threshold=0ns
L1SubCtl2: T_PwrOn=10us
FYI, my environment is Ubuntu 20.04(5.10.216-tegra), Nvidia Xavier NX.
At first, I hadn’t decided which protocol to use, so I requested both PCIe and USB. I’ve now decided on PCIe.
After update-pciids now I got correct name.
Quectel Wireless Solutions Co., Ltd. EM120R-GL LTE Modem
Sugsystem: Quectel Wireless Solutions Co., Ltd. Device 2001
@jfrog Could you please check it once more?
jfrog
July 5, 2026, 10:18am
9
This device is not yet supported by the standard Linux driver in 5.10.216
You’ll need to upgrade your kernel or perhaps patch & re-build the old driver.
If I’m not mistaken, support for this model was added in 6.0
Actually, I did confirm that it works using an MHI driver I found somewhere online and patched by myself, but I can’t really trust it. Still, I’d like to patch it myself and give it a try, so could you send me the driver?
jfrog
July 5, 2026, 1:45pm
11
