which is the original firmware version, also mentioned in the documentation.
Digikey talked about the more recent version LG69TASNR01A03.
Can you provide me the firmware release notes and update file ?
Internal test data: LG69TAS working temperature grow from 30 Celcius degree to 52 Celcius degree. And keep stable 52 Celcius degree after power up for half an hour.
We test on evaluation board and room temperture 26 Celcius degree. If customer use a smaller baseboard, the temperture will be higher. You can add a heatsink.
