Hi Teams,
I’m using LG69T AP modules now, after reading the document, I have the following questions:
FW version :
$PQTMVER,1,MODULE,LG69TAPNR01A01S_CQN4,2023/06/01,11:09:222B
$PQTMVER,10,RTK,V1.1.1_230516_QNE_GNSS_1HZ_B_RELEASE26
$PQTMVER,11,DR,V3.0.1_230516_QNE_NAV_A_RELEASE*50
1.How can I setting the DR/RTK mode switch?
In Quectel_LG69TAMAP_GNSS_Protocol_Specification_V1.0.pdf 2020/06/15
version1.0 have command as below,
$PQTMCFGDRMODE (for setting speed mode)
$PQTMCFGWHEELTICK (for reading wheel ticks)
version1.2 2024/04/29 remove these commands.
2.When use DR mode, how to select vehicle speed input?
$PQTMCFGVEHDBC (setting type of speed)
$PQTMCFGCAN(setting CAN ID for input)
then send message via CAN bus?
The wheel-tick pulse is injected through the module pins,
DR mode requires one or both of the above?
When pin RTK_IND is high level, GNSS is in RTK fixed mode?
thanks.
