LG290P Won't boot, BOOT ERROR: BP Package load failed after ECC correction
I’ve been testing a lg290p board with windows software and one day or night It stopped getting a lock. After looking into the reason why it stopped responding, I found that the board is giving the following error:
Over and over, It was stable for a few months, and I hadn’t changed any settings for the past weeks since I was developing software. Any advice?
Quick update:
I wasn’t able to flash the firmware because I was trying to use the speed that I was using before (115200), I changed to the default 460800, and I was able to flash, and seems like that was the problem.
So if someone has this problem: re-flash the firmware, you still should be able to do it.
Cause? I’m not sure, perhaps a really poorly timed power loss.
:+1:
