Greetings,
with LG290P (but I’m also interested in lc29ea) is it possible to set the cut-off angle?
I should set an angle of 20°.
Greetings and have a good day everyone
AF
Una sintesi di comandi per LC29H_EA
$PAIR864,0,0,460800*16 Set baud rate to 460800
$PAIR382,1*2E → Test command for lock system sleep enabled
$PAIR003*39 Power off the GNSS system, including DSP, RF, PE and clock
$PAIR512*3C Clear all data
$PQTMRESTOREPAR*13 Clear all data to default
$PAIR514*3A Clear the current configuration and restore the pair settings.
$PAIR511*3F Save current navigation data from RTC RAM to flash
$PAIR513*3D Save the current configurations from RTC RAM to NVM.
$PAIR023*3B Reboot
$PAIR007*3D Perform a cold start and clear system/user configurations.
$PQTMGNSSSTOP*09
$PQTMCFGRCVRMODE,W,1*2A Set Rover mode
$PAIR062,1,0*3F Disable GLL sentence.
$PAIR062,2,0*3C Disable GSA sentence.
$PAIR062,3,0*3D Disable GSV sentence
$PAIR062,4,0*3A #Turn off RMC messages
$PAIR062,5,0*3B ; Disable VTG sentence.
$PAIR062,-1*0E Default enable all nmea
$PAIR050,200*21 ; Set position fix interval to 5Hz (200ms).
$PQTMCFGNMEADP,W,3,8,3,3,3,3*39 ; Max decimal places
$PAIR058,35*1D ; Sets the minimum SNR to 35
$PAIR070,1*20 Sets the static navigation speed threshold to 1 dm/s 1 dm/s = 0.1m/s
$PAIR072,15*17 ; Set satellite elevation mask to 15 deg.
$PAIR072,20*11 ;Set satellite elevation mask to 20 deg.
$PAIR072,45*12 ;Set satellite elevation mask to 45 deg.
$PAIR074,1*24 ; Enable active interference cancellation (AIC) function
$PAIR080,0*2E ; Set navigation mode = normal (mode 0).
$PAIR391,1*2C ; Enable jamming detection.
$PAIR534,0*24 disable eph notif. for newly updated EPH.
$PAIR410,0*23 Disable SBAS feature
$PAIR400,0*22 disable sbas input Set none correction source.
$PAIR401*3F ask sbas input
$PAIR473,1*27 ; Enable EPO data aiding & limits saving the flash range to 80K
$PAIR092,0*2D ; Set non-static mode
$PAIR753,1*26 ; Enhance PPS timing accuracy
$PAIR083,0*2D get fix in high sensitivity tracking
$PAIR606,0,0,0,0*3A no PR residuals
$PAIR710,1*21 adaptive L5 when GNSS system is powered off
$PAIR513*3D ; Save current configurations from RTC RAM to NVM.
$PQTMSAVEPAR*5A ; Save configurations into NVM.
$PAIR002*38 gnss start
per la lg290p non ci sono riferimenti
We ask quectel staff @george.gao if can provide doc
Thanks @bamarcante and @splee for the assistance.
So regarding LG290P to have a cut-off of 20 degrees I have to insert 20 in the highlighted parameter?
AF
This command only seems to affect the satellites used for RTCM data/messages. I don’t know if it affects the satellites used for local GPS calculation…I did not see any other elevation commands
