I’m writing to you to get help with the problem while we read GPS data. Sometimes LC86L sends the same data for 20-40 seconds or more. I mean we see on the terminal the same coordinates for a long time. Please help us.
Hi Minaye,
Can you confirm if UTC time outputed from LC86L didn’t change or not? Did the module output totally same data( including time, position, satellites info) in 20-40 seconds?
Or the only unchanged data is position?
Best regards
Output is totally same
Hi Minaye,
I will send you latest LC86L firmware via message. Please upgrade to the module and check if situation change.
There is another possibility that the host’s(MCU) buffer is not cleared, and resend same data.
Best regards.
