I am using LC86L Module in our project, When I try to receive the GNSS NMEA Data using Internal patch antenna, I am unable to receive Latitude and Longitude data. I have attached a small log related to GPS Data
When no external active antenna is applied, the module will use its internal patch antenna by default. From your attached log, “$GPTXT,01,01,02,ANTSTATUS=OK*3B” means the antenna is functioning well.
Could you please confirm your test environment is open sky where GNSS signals can reach the module without obstacles?
Could you please provide your firmware version? You can check it with the command below:
$PQVERNO,R*3F
Answer to Question-2:
In order to get higher signal level, an active antenna (with LNA) is recommended. For detailed information and reference design, please check “5.2 External Antenna Design” from the attached Hardware Design.
