I’m starting to work with LC86GLA and I’m now testing 3 units.
After a few days, one of the units stopped sending NMEA frames (RMC, GGA, etc.), it only outputs the following information during its initialization (when turned on):
[Bootloader] bl_uart_init done
set CP10 and CP11 Full Access
[CLK] Dynamic Clock Management: Enable
[CLK] frequency meter
CM4(CMSYS) freq [215974]KHz
BUS(FSYS) freq [107974]KHz
SFC freq [107974]KHz
SPISLV freq [0]KHz
I3C freq [108000]KHz
RTC SRAM freq [107974]KHz
hal_flash_init
BL Jump to addr 0x8009000 (0)
$PQTMVER,1,MODULE,LC86GLANR12A02S,2023/12/26,09:53:00*11
I had tried to send $PAIR007 to reset the module to its factory default settings but still same behaviour and no NMEA frames.
I would really appreciate any comments on what the problem and root cause of this unit’s failure could be, as I am now evaluating Quectel GNSS LC86GLA to be used in series production for a project.
Tks!
VCC is supplied from the same 3.3V supplying my ESP32 (Lilygo T-SIM7000)
VBCKP is connected to an MS621FE rechargable 3V cell
The input power is using a DC-DC converter with TVS that takes 12V to 5V which then goes into the Lilygo LDO and power circuitry.
All PAIR commands do not get ACK, so there is no effect. The device tries to JL from bootloader and there afer reboots as if the watchdog triggered it.
There can be cases when the power turns off suddenly (as it is connected to a vehicle). The device ran fine (roughly running 9-10 hrs a day) for about 2 weeks and then between week 2 and 3 we saw multiple devices fail in the same way. This was also a period of increases solar activity.
