Hello, I have a GPS module LC86G, and I test it in one place for a long time
the coordinates all time are different I took about 800 RCM readings.
why coordinates are different in same place?
Hi @HamdyNassar2024
The positioning accuracy of the LC86G module in the open environment is 1.5 m. In different environments, the positioning accuracy will have some deviations.
What is the environment you tested in? Is there any obstruction? Please provide specific information. Can you also provide the positioning information you received?
Hi George,
Thanks for your replaying, I tested LC86G in my company, I put the GPS external antenna out of window.
below are some samples:
2956.844042,3052.318656
2956.843592,3052.319022
2956.842992,3052.319892
2956.844498,3052.321008
2956.847090,3052.319814
2956.844438,3052.317882
2956.842038,3052.318248
2956.841246,3052.316556
2956.842080,3052.317804
2956.841774,3052.317006
2956.840922,3052.315380
2956.841996,3052.315614
2956.842074,3052.315842
2956.839740,3052.313646
2956.839416,3052.313088
2956.839452,3052.313172
2956.839278,3052.312776
2956.838744,3052.311378
2956.838432,3052.311264
2956.837802,3052.310022
2956.841126,3052.314234
2956.842434,3052.316454
2956.842266,3052.317582
2956.842386,3052.317678
2956.843820,3052.319628
2956.843628,3052.319646
2956.843724,3052.318656
2956.845740,3052.319754
2956.847192,3052.320768
2956.846898,3052.319508
Hi HamdyNassar,
Can you provide NMEA test log through message? I want to check the signal level when you are testing.
You can also check the signal level by connecting module to QGNSS tool. You can download QGNSS tool for firmware upgrading and debugging on Quectel modules. Download link:
Example:
You can also find the test log in this path:
Best regards.
