accordingly to the documentation I noticed that there a lot of warning for the $PAIR050.
Does LC79HAL support 10Hz update rate without issues?
Is $PAIR050,100 the only command needed?
Should I change the baudrate?
thanks
KR
C
thanks
KR
C
Hello Raphael,
any update on that?
thx
Hi Carlitos,
LC79H supports 1~10 hz update rate.
Set 10Hz update:
$PAIR050,100*22 //set 10 hz
$PAIR513*3D //save parameters
restart the module
The baud rate should be not lower than 115200bps.
Best regards.
Hello Raphael,
can be possible to get the schema of the EVK of the LC79H module?
it will help my HW dept colleague.
thanks.
C
any update on this, Sorry but we need this.
thx
KR
@Raphael-Q , any update about this topic?
thanks
Matteo
Hi Matteo,
I will send you EVB schematic via message.
Best regards.
Hello Raphael, write you a message.
I got issues opening it.
thx
