When does the LC79H module set its ANT_ON output high? What is the criteria that its firmware uses to decide when to set this pin high or low?
What I know is that when ANT_ON pin outputs
high level, the antenna is powered, otherwise, the antenna is not powered.
Best regards
Hi Patrik and Cassiel,
LC79H ANT_ON pin outputs low level when the module set to Backup Mode. It outputs high when Continuous Mode.
Best regards.
