[LC29HEA] Support for Aiding Commands to improve TTFF without RTC battery?
I am currently developing a product using two LC29HEA modules in Moving base
I did not include an RTC backup battery (the V_BCKP pin loses power when the main system is turned off). As a result, the modules perform a Cold Start every time the system powers up, which increases the Time To First Fix (TTFF).
However, I noticed in my UART boot logs that the LC29HEA sends these specific messages right before outputting standard NMEA:
Plaintext$PAIR011,001*27 $PAIR010,1,-1*16 $PAIR010,2,-1*15
I suspect $PAIR010,2,-1*15 is an Aiding Request for the last known position and time. I can easily save the position/time before shutdown and inject it back at boot.
My questions are:
  1. Does the LC29HEA firmware fully support receiving Aiding data (Time and Reference Position) via UART to speed up the TTFF during a cold start?
  2. If yes, what is the exact $PAIR command (or standard NMEA command) I should send to answer the $PAIR010 request and inject this data?
  3. Is there any specific documentation or application note regarding Aiding/EPO injection for the LC29H series?
Thanks in advance for your help!
Hi @zizouth
Please refer to the following answer to your questions
    Yes
    You can use both PAIR590: PAIR_TIME_SET_REF_UTC and PAIR600: PAIR_LOC_SET_REF to send reference time and location for aiding TTFF
I will send you the documentation via email. Please let me know if you have received it
Best regards,
