LC29HEA - problem with unstable location
Hello, the latitude and longitude change by up to 8 meters for 15 minutes even though the module (LC29HEA) and the antenna are stationary in the same place. What could be the reason for this behavior?
Hello Fabian, it happens to me sometimes but the error is related to the management software not to the chip; I use satrack that has the advantage of connecting in tcp remotely…but sometimes happens:
and need to refresh only the map_window.P.s.
I really hope that the new firmware is not at cause about the limitations due to conflicts in the world. I have to retrieve some chips that I had kept before the events and I remember that the suppliers asked explicitly what I should do with them…
unfortunately mea messages also show shifting :frowning:
Hi Fabian, morning happened too,but pos in log was fine, also the pos_info windows …
Join this topic:Firmware Request: LC29HEA Adjustable Update Rate for Ardupilot Utilization
U are also on ardu_forum, right?
Is this HDA or HEA module…
There is strength in numbers
Marco
