I have the LC29HDA gps module delivered tomorrow.
Exactly, I bought the model shown in the attached photo. Questions: 1) can I power the uart vcc pin with 5v?
2) can I use it together with LC29HEA to create a Base / Rover system?
Thank you
AF
Thank you
AF
You can see from the board picture below that there is a voltage regulator chip on the board (marked in yellow), so it’s a safe bet that you can feed the board with 5V
As far as working together, from the data sheet below, it looks like the only difference between the HDA and HEA is that the HEA can support a higher output rate:
Ok @splee thanks for the info. I was too optimistic about the delivery time of the form and will have to wait a few more days.
Then I’ll also let you know why I’m quite unprepared for the base/rover connection.
I apologize for my other last message (data via uart) but the “google translator” perhaps did not completely understand the “idiom” of my country.
Greetings
AF
Yes, it’s better if you describe what you are trying to achive overall…It makes it easier to help you.
