I am facing an issue with my LC29HDA RTK rover module. I connect to a base station via an NTRIP caster to receive GNSS corrections, but I am unable to get an RTK Fixed or even RTK Float solution via AGNSS. The best signal I am able to obtain is DGNSS.
Here are some technical details regarding the issue:
- The base station only broadcasts corrections on L1 and L2.
- My LC29HDA RTK rover module works on L1 and L5, and I am wondering if the difference in frequency bands between the L5 of the rover and the L1/L2 of the base station could be causing the problem.
- I have tested the module away from buildings and walls, in open conditions, to eliminate environmental interference.
- I have performed tests using both RTKLIB and NTRIPClient, but I still cannot achieve an RTK Fixed solution.
Despite having a stable NTRIP connection and receiving corrections from the base station, I am unable to get a stable RTK correction or fix.
If anyone has encountered a similar problem or can provide insight into this, any help would be greatly appreciated.
Thank you in advance!
