LC29HDA and RTKNAvi
It’s possible to connect LC29HDA rover to RTKNavi? What’s the Input stream format from serial port on RTKNavi configuration?
I have a Fixed RTK in QGnns, so the module it’s working fine with my ntrip caster
thanks
Luca
Hi Luca,
You can select base station as input, and rover as output. The type of input/output is decided by the way of communication between base and rover.
Best regards.
