The module not correspond to the command $PQTMVERNO*58 and other commands, so it is impossible to connect the RTK mode. The NTRIP client works, accepts data, but the correction is not displayed.
Hi Antyk
You need to add a carriage return and a line feed when sending a command.
For example, you need to add a carriage return and a line feed when sending the command “$PQTMVERNO*58”. That is, “$PQTMVERNO*58\r\n”.
Hello, george.gao! Thank you for your help. I’ve already learned how to type commands. Best regards.
