LC29HB latest firmware and datasheets
Hi Support,
I recently purchased a LC29HBAMD RTK & DR on Aliexpress and would like to flash the latest firmware. Also I would need the documentation referenced in the Quectel_LC29H_Series_Hardware_Design_V1.0.pdf:
I would need at least the documents [1] - [4].
Thank you in advance!
Peter
Hi Pstumbler,
The documentations are sent via your meesage.
Best regards.
Good Morning Raphael-Q!
Thank you very much for the documents, firmware and link to QGNSS tool!
Kind Regards
Peter
Hi Raphael-Q,
now I have problems with the items I ordered… :frowning_face: - I don’t get them.
Is it possible to purchase 1 or 2 samples directly from Quectel?
Or do you know here I can get any LC29HBAMD?
Thanks you!
Peter
Hi Pstumbler,
We don’t have an online mail like Amazon. Please send your name, city and country you based, and email via MESSAGE. I will try to find a sale to contact with you.
Please make sure the OC( ordering code ) of the product that you need.
OC: LC29HBAMD is a piece of module.
OC: LC29HBAEV is an EVB for testing. And LC29HBAEK is LC29H-EVB-KIT
Or you can contact with them by yourself.
Best regards.
Hi Raphael-Q,
thanks for your answer.
I will try to contact directly.
Best Regards
Peter
Hi, is there anywhere sample code for the communication? I was hoping I can do the configuration with the QGNSS tool, but this can’t do any configuration…
Examples for the PAIR implementation?
Thanks Martin
Hi Martin,
QGNSS is an useful tool for GNSS testing via UART.
  1. First, connect the module to QGNSS
  2. Turn on command console, and you will be able to send commands.
  3. After inputting a command, check CRLF( Carriage-Return Line-Feed ) and then click send. You can find feedbacks in the text data windows below.
  4. The tool also contains checksum calculation function. Input a command without [ *] part, and then check NMEACHECKSUM. The checksum will be automatically calculated by the tool.
Hello Raphael,
could you support me with getting new firmware for LC29HBA module?
Currently we have
Eval board:
LC29HBANR11A01S_CSA4
Our product:
LC29HBANR01A04S_CSA4
Thank you
Hi Petr.svabenik,
I will send you via message.
Best regards.
Hi Raphael,
Could I please also be sent the four documents pstumbler requested at the start of this thread and the latest firmware for the LC29HDA?
Thanks in advance!
Hi As5000,
I will send you the latest firmware via message.
Best regards.
Can you send me last firmware LC29HBS please?
