Hi.
I implemented LC29HAA GPS-module as dual band, but it doesn’t see any L5 or B2 satellites.
What is wrong?
I use no-name active antenna from Aliexpress.
Is this module able to see that satellites?
I give command:
$PAIR105
Answer:
$PAIR001,105,0
$PAIR105,1
Hi Isstar,
LC29HAA module is a dual band module and L1+L5 is enabled by default.
Please check the firmware version on your module by sending: $PQTMVERNO*58
Please check the antenna specification. Probably you are now using a single band antenna. An L1+L5 dual band antenna should support 1559–1606 MHz(L1 band) and 1164–1189 MHz(L5 band). And the recommended antenna specification is shown below.
Best regards.
It was the antenna. Now I connected YB0017AA from Aliexpress and everything is fine.
