Hello Q Forum,
Since we read the article over linkedin, we are interested to check LC29h module.
Can I have the following document?
Quectel_LC29H_Series_Hardware_Design_V1.0
Quectel_LC29D_Hardware_Design_V1.0
Quectel_LC29D_DR&RTK(0)_Application_Note_V1.0
Thanks in advance,
Best Regards,
CArlos
Hello Raphael, thank you Very much for your support.
Reading over the document I’m not sure that I’ve catch basic information, I mean.
LC29H is mentioned than there is other variants inside (5 variants) are all of those based on which chipset?
LC29D looks like the command is different, is based on different chipset even if the form factor is the same?
