LC29H -DA and BS module configuration and latest firmware with documentation
I am new at this so I may be entering an incorrect message here!
I have two LC29H, one Base and one Rover. The versions here below.
$PQTMVERNO,LC29HBSNR11A01S,2023/02/13,10:14:06*27
$PQTMVERNO,LC29HDANR11A03S_RSA,2024/03/19,13:55:31*20
Can you please send me the link to the manuals corresponding to these versions?
I found many manuals and I am not sure which one I need to use.
Also, can you perhaps email me a firmware upgrade if that exists?
And if possible also with updted manuals if that is needed.
Many thanks in advance!
Kind regards!
Hi @janw I have sent the latest FW version to your email. Please do let me know if you have received the FW package. For BS, the version you have is the latest. Best regard.
Hi, I have the LC29H DA module, can I get the latest firmware? My email is hoppingturtles@proton.me. Thanks!
Hi @hoppingturtles,
Could you share with me which FW version you are using right now?
Hi, my firmware is LC29HDANR11A03S_RSA (built 2024/03/19 13:55:31)
Hi @hoppingturtles, please check your email. I have sent you the latest FW version on there.
i have a lc29hDA vrsion.
$PQTMVERNO*58
$QTMVERNO,LC29HDANR11A03S_RSA,2024/03/19,13:55:31*20,
The LC29HDA is configured as a rover and receives RTCM corrections either from an LC29HEA located 2 meters away with fixed coordinates and configured as a base, or from the IGN mount point ZARA0 in Spain, located 8 km away. I achieve RTK fixed, but the precision does not go below 51 cm, when according to the specifications it should be around 1–2 cm. Is it the firmware, is it the configuration?
HI! I have a Waveshare Raspberry Pi HAT with the LC29HBS module. My current firmware is returned by the module is LC29HBSNR11A01S even though I just purchased it. Can you please send me the latest firmware for this module? Thank you.
HI @cap9qd Unfortunately, LC29HBSNR11A01S is the latest firmware for LC29HBS. Please take note as well where this LC29HBS module already EOL. Best regards,
Thank you for your reply and confirming the latest firmware. Maybe I have an antenna or cable problem that prevents my survey in be successful. Thanks again!
