LC29H BS Only gibberish on serial communication
Lc29h BS only gibberish on serial communication. Baud rate 115200. After pressing reset button I get clear text and after that all gibberish sent every second.
this is what I get after reset.
But QGNSS seems to work but cant get a fix.
Hi David Licic,
LC29HBS outputs RTCM data in binary format. In QGNSS, you can open Binary data window to monitor RTCM data which is coverted to HEX format. You can open Message View window to monitor the current coordinate of LC29HBS.
Once the coordinate (in RTCM3 1005) fixed, LC29HBS can work as a base station and send correction data to rovers.
is possible to get the latest firmware for LC29HBS module and documentation?
thanks
BR
C
Hi Carlitos,
I will send you the documents via message.
Best regards.
