LC29H(BS) After Survey done cannot show the coordinates
After the survey mode done and saved the location, the LC29H(BS) I guess need a firmware update, because was really difficult to setup as base and rover the two boards.
Could you please send to me a new firmware for this base station ?
After survey done, they never show the latitude and longitude in the log view.
Regards and thank you for the support.
Hi jmsprenger
  1. Please use “$PQTMVERNO*58” to query the software version number to confirm the current software version.
  2. LC29HBS only outputs RTCM data by default.
  3. Please refer to the “PQTMCFGSVIN” and “PQTMSVINSTATUS” commands in the Quectel_LC29H&LC79H&QLM29H_Series_GNSS_Protocol_Specification document to confirm whether the survey-in function configuration is correct and whether the survey-in convergence is successful.
