The LC29H AA module works for 2-3 minutes, after which the message “The module is not in service area” appears in the protocol, what should I do?
Hi Dandy96,
I will send you corresponding documents via message.
Best regards.
Hi. I have the same problem. Can you send me this document too?
Hi dfhj
- Please use the “$PQTMVERNO*58” command to check the version of the module and let me know.
- Please describe the current problem or provide the current log.
$PQTMVERNO,LC29HDANR11A02S_RSA,2024/01/31,15:17:36*2E
After turning on the module, when it starts receiving coordinates, an error appears: “$PQTMTXT,1,01,01,03,The module is not in service area.*31”. I live in Russia, I think the problem arose because of this. I would like to get around this problem, maybe you have firmware for this?
Hi dfhj
This is not a solution. My module still does not work.
Hi dfhj
The module does not work in certain areas. Please consult the documentation.
Have same problem: “The module is not in service area.*31””
Can u give solution for me?
Hi @Lsrgcnmy
Please contact your local sales or FAE.
The LC29HBSMD Q1-C1145 model permanently fails after 1,01,01,03.
The $PQTMVERNO 58 command does not work, there is no response.
The LC29HBSMD Q1-C1145 model constantly fails after $PQIMIXT,1,01,01,03. The $PQTMVERNO 58 command
$PQTMVERNO,LC29HBSNR11A01S,2023/02/13,10:14:06*27
Note,output of $PQTMVERNO 58 command can be $PQTMTXT,1,01,01,03,This version is not licensed, please contact FAE.*7C.
If U see “The module is not in service area", the module does not work in certain areas with newer fw…
And is it possible to roll back to the old tailoring? or there is no such option. The zones are quite strange, it does not work in the countryside, but it works in the city.
Sorry, I meant to say that it does not work in certain nations due to the sanctions…
To roll back U can try to ask for LC29HBANR01A04S_CSA4 if available.
Regards
Good afternoon, can I ask for advice from bamarcant on the firmware from the ba module? Or maybe you need a new firmware, or vice versa an older one. where there are no restricted areas. or they are smaller. He works for me in SPb, but I want him to work in the nearest district too.
Errata corrige:(I misread the model)
LC29HBSNR11A01S is the latest of this module ( I suppose it is the AA model customized).
So there are LC29HAANR01A02S if also for BS version…
Greetings.
Module LC29HEANR11A03S_RSA,2023/10/31
after 3 minutes I get
$PQTMTXT,1,01,01,01,03,The module is not in service area.*31.
What firmware should I flash to fix it?
$PQTMVERNO,LC29HBANR11A02S_CSA2,2023/05/09,20:49:45*0A
Did U received/read last inbox message 10/november?
