Would it be possible for you to provide the following information:
LC29D GNSS DR & RTK Application Note
Quectel QGNSS User Guide for QGNSS v1.5.2
QCOM Tool for communicating with the LC29D EVB
QCOM User Guide
GNSSFlashTool that can be used with the LC29D EVB (for example, v1.13 or the latest)
Schematic and layout files for the LC29D EVB
Is there a way to disable dead reckoning (for example, using a command) in LC29DAMD module, and only use dual-band GNSS (i.e., autonomous mode) for position output?
Would it also be possible to provide all of the above for the L79D module?
I am testing an evaluation board (LC29D-EVB_v1.2) along with QGNSS v1.5.2 Build 0608. The antenna used is the one that came with the evaluation board. It does not seem to detect Galileo satellites. Does the module require a newer special firmware to detect Galileo satellites?
Is there a document that lists the commands that can be used to configure the LC29DAMD module?
Dear Sir
Sorry for the late reply.
The tools and documents mentioned in 2-6 and 10 above have been sent by email, please check.
For the documentation of point 1, please help provide the following information:
What product is it applied to? Two-wheeled vehicle (scooter, electric vehicle, etc.) or four-wheeled vehicle (car, etc.)
——Not currently supported.
——Galileo satellites generally require a longer search, such as ten minutes.
——Refer to the LC29D protocol document.
We would like to use this module in an application that does not have wheels. We are mostly interested in the dual-band capability and wanted to operate it in autonomous mode (without dead reckoning or RTK). Is this recommended?
In response to your reply (7), could you tell me what would happen if LC29DAMD is not fed with wheel speed input (wheelticks and FWD signals)? Would the device still work? Or is this mode of operation not recommended at all?
If we wish to evaluate a dual-band module for simple asset tracking (without any wheels), what module would you recommend? Should we go for LC79D instead?
Regarding (9), I have the GNSS protocol specification v1.0 (2021-01-19). This does not have any commands listed in it. Is there a newer version of this document?
Could you also send the latest firmware for the LC29DAMD module?
——There is no autonomous mode version yet.
——It is not recommended to use this way.
——Recommend LC79D or LC29H.
——No update at the moment. For configuration commands, please refer to section 3.6, which is the Bream protocol.
I have not received it. But I’ll wait and see. Thanks.
But perhaps I will evaluate LC79D then. I have a development board.
Could you tell me where can I find the latest documents and firmware for LC79D module?
