Hi support team,
Recently, I purchased these two modems, the Quectel EG800 and EG915, but unfortunately, they did not work as expected.
I would kindly like to request the latest firmware versions for the EG800 and EG915 modules.
AT+CVERSION
VERSION: EG915QNALCR01A05M04
Jun 21 2023 12:16:27
VERSION: EG800QEULCR01A11M04
Oct 22 2024 09:22:43
Authors: QCT
I have sent the latest firmware to your email, pls check
Hi Herbert.
I have several E915 modules and I am experiencing some errors related to UFS. Can you send me the last FW version for these modules.
Thank you in advance!
What is your current firmware version? Please specify. Thx
Hi Jonathan,
We are currently using version EG915NEAAGR03A12M08
Thank you in advance.
I have firmware EG800QEULCR01A11M04 but I need VoLTE functionality. May i receive the firmware including the Voice functionality please ?
Thanks a lot !
Lionel
I need new firmware, my current is EG800QEULCR01A11M04
Can you send instruction how to flash too?
thanks,
Krystian
Hello, can I get latest firmware version as well as instructions how to flash ?
My current one is EG800KEULCR07A07M04
Hi, I have sent the firmware and flashing instructions via email, pls check it, thank u.
Thanks a lot !
Lionel
Hi Quectel support team,
Could you please send me the latest firmware for the EG800Q-EU, with flashing instructions?
I need a release that fixes a TLS SNI bug described below.
Module and versions
- ATI: Quectel EG800Q-EU, Revision: EG800QEULCR01A11M04
- AT+QGMR: EG800QEULCR01A11M04_A0.300.A0.300
- AT+CVERSION: VERSION: EG800QEULCR01A11M04, Jul 8 2025 15:44:26, Authors: QCT
- Host: custom board, dsPIC33EP512GM706, main UART at 115200 baud
Problem
With AT+QSSLCFG=“sni”,1 the module sends the server_name (SNI) extension TWICE
in the TLS ClientHello. Servers reject this (RFC 5246, 7.4.1.4), so:
- AT+QSSLOPEN returns +QSSLOPEN: ,579
- AT+QMTOPEN returns +QMTOPEN: 0,5
With “sni”,0 no SNI is sent and the TLS handshake succeeds, but brokers that
need SNI (HiveMQ Cloud, EMQX Serverless) then refuse the MQTT session (CONNACK 5).
How I checked
- Captured the module’s own ClientHello through a local “TCP LISTENER” socket and AT+QIRD.
The extension appears twice in a row (type 0x0000, length 0x0024):
00 00 00 24 00 22 00 00 1f <31-byte host name>
- Same result with sslversion 3, 4 and 5, with QSSLOPEN and QMTOPEN, with seclevel 0
and with seclevel 1 + CA certificate.
- Replaying the captured ClientHello from a PC: with two SNI extensions the servers answer
a fatal alert (decode_error / illegal_parameter); with one, they answer ServerHello.
- SNI=1 fails on www.google.com:443, test.mosquitto.org:8883, broker.emqx.io:8883,
HiveMQ Cloud and EMQX Serverless. SNI=0 succeeds on all of them.
Request
- Latest EG800Q-EU firmware where SNI is sent only once, plus the upgrade procedure
(DFOTA or QFlash).
- If no fixed release exists yet, could this be forwarded to R&D?
I can provide the full ClientHello capture if needed.
Thank you,
Tomas
Dear Customer,
I have sent the requested firmware in your email. Please check there.
