Latest Firmware Version for Quectel RM520N-GL - 5G problems
I am currently using the Quectel RM520N-GL modem and am experiencing issues with registering to the 5G network. I have tried various configurations, including setting the rat_acq_order to NR5G and adjusting the nr5g_band settings, but I am still unable to register the modem to the 5G network.
Additionally, when I check the registration status with AT+COPS?, I receive code 13, and when using AT+QNWINFO, it returns LTE as the current network.
Could you please provide me with the latest firmware version for the RM520N-GL? My current firmware version is RM520NGLAAR03A03M4G_01.201.01.201.
I would appreciate your assistance in resolving this issue.
Dear @rayfoll
13 means NSA, did you confirm there have SA network on your side.
You can also use AT+QENG=“servingcell” to check.
I will sent the firmware to your eamil, please check later.
Dear Silvia,
I wanted to inform you that I have resolved the issue with registering the modem to the 5G network. It turned out that the problem was caused by the network operator.
Nonetheless, I sincerely thank you for sending the latest firmware—it is greatly appreciated.
Thank you once again for your support.
Hey guys, I’m dealing with the same issue and would like the latest firmware for the RM520NGLAAR03A03M4G_01.201.01.201 firmware version as well please!!
Dear @ScottPockets
I have sent to your eamil, please check.
Dear Silvia,
I hope you are doing well. I bought 2 Quectel RM520GL-N module but struggling to connected to 5G. I also understood it depends on many factors, such as
  1. Check Firmware and Settings: Ensure that your modem’s firmware is up to date. You can also try using AT commands to lock the modem to 5G. For example, use AT+QNWPREFCFG=“mode_pref”,NR5G to force the modem to prefer 5G networks
  2. Verify Network Compatibility: Confirm that Vodafone’s 5G network in your area supports the bands used by the RM520N-GL. Sometimes, the modem might not be certified for use on certain networks [Vodafone network UK is compatible with Quectel]
  3. Antenna Configuration: Make sure all antennas are properly connected to the modem. Incomplete antenna setups can affect the modem’s ability to connect to 5G
  4. Location Testing: Try connecting from different locations to see if the issue persists. Sometimes, moving to an area with better 5G coverage can help
how to get RM520NGLAAR03A03M4G_01.201.01.201 firmware to start with it? n how to upgrade it on Window or Ubuntu laptop?
Many thanks, Jigar
Dear @shah
Do you want to get RM520NGLAAR03A03M4G_01.201.01.201 or the laetst firmware version?
Dear @silvia,
The Current firmware: RM520NGLAAR03A04M4G.
I need the firmware - which is reliable and stable for the modem. how do I update the modem if I am using Windows/Ubuntu laptop - connected through USB 3.
Once again, thank you, SHAH
Dear @shah
I have sent the latest firnware to you, please test again.
Hello
can I please get the latest firmware version.
Dear @Quectel-user
Hello
Thanks my actual software revision:
RM520N-GL
Revision: RM520NGLAAR01A07M4G
Dear @Quectel-user
I will sent to your email, please check.
Hi @silvia , could I get the latest firmware as well?
Currently
RM520N-GL
Revision: RM520NGLAAR03A03M4G
Dear @iankeefe12
May I also please get the latest firmware? Thank you
Will the latest firmware everyone is getting work with my device? It is manufactured by quectel. The device is also using rm520gl. It is a gateway from suncomm model O1. I cannot seem to find an updated firmware anywhere for it. Thanks
Dear @Johnny_Phan
You can also contact with your provider to get.
May I also have the latest RM520 firmware? I am on RM520NGLAAR03A03M4G
Hi,@aigochamaloh
I have sent it to you via email, pls check.
