Hi
I need the latest firmware of EC200TCNLA-N06 module, how and where can I download it?
EC200T has been discontinued, the latest firmware version has been sent to your email
When I opened QFlash_4.19 I recived this Error:
“Error, Tool can not detect platform name!”
Do not decompress the firmware file and import it directly
After I upgraded your zip file on the module, the module stopped working and the serial ports were no longer recognized by Windows.
Well, then things got really bad. Maybe the module turned into a brick ![]()
I can upgrade module again but this module dosen’t work. can you help me?
Is the main serial port or USB port back to normal?
it seems usb for upgrading is ok but after restart module I cant see any port in windows.
Connect it to any Linux host or OpenWrt router and show the output of cat /sys/kernel/debug/usb/devices
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
B: Alloc= 0/800 us ( 0%), #Int= 3, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 4.14
S: Manufacturer=Linux 4.14.248 ehci_hcd
S: Product=EHCI Host Controller
S: SerialNumber=101c0000.ehci
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 4
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1a40 ProdID=0101 Rev= 1.11
S: Product=USB 2.0 Hub
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=100mA
E: Ad=81(I) Atr=03(Int.) MxPS= 1 Ivl=256ms
T: Bus=01 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 3 Spd=480 MxCh= 4
T: Bus=01 Lev=03 Prnt=03 Port=00 Cnt=01 Dev#= 5 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=ff(vend.) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=1a86 ProdID=7523 Rev=81.32
S: Product=USB Serial
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=01 Prot=02 Driver=ch341
E: Ad=82(I) Atr=02(Bulk) MxPS= 32 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 32 Ivl=0ms
E: Ad=81(I) Atr=03(Int.) MxPS= 8 Ivl=1ms
T: Bus=01 Lev=03 Prnt=03 Port=01 Cnt=02 Dev#= 7 Spd=12 MxCh= 0
T: Bus=01 Lev=03 Prnt=03 Port=02 Cnt=03 Dev#= 9 Spd=12 MxCh= 0
T: Bus=01 Lev=03 Prnt=03 Port=03 Cnt=04 Dev#= 11 Spd=12 MxCh= 0
T: Bus=01 Lev=02 Prnt=02 Port=01 Cnt=02 Dev#= 4 Spd=480 MxCh= 4
T: Bus=01 Lev=03 Prnt=04 Port=00 Cnt=01 Dev#= 6 Spd=12 MxCh= 0
T: Bus=01 Lev=03 Prnt=04 Port=01 Cnt=02 Dev#= 8 Spd=12 MxCh= 0
T: Bus=01 Lev=03 Prnt=04 Port=02 Cnt=03 Dev#= 10 Spd=12 MxCh= 0
T: Bus=01 Lev=03 Prnt=04 Port=03 Cnt=04 Dev#= 12 Spd=12 MxCh= 0
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 1
B: Alloc= 0/900 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0001 Rev= 4.14
S: Manufacturer=Linux 4.14.248 ohci_hcd
S: Product=Generic Platform OHCI controller
S: SerialNumber=101c1000.ohci
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=255ms
Technically you have no modem attached.
I’m wondering if you have anything in the system log right after the modem is attached.
it seems the module boot doesn’t work. because wan led is off. but when I Use Qflash and connect module to usb port qflash started upgrading.
Is it possible to solve the problem by replacing the firmware with another version?
I also need this latest firmware.
Can you help sent it for me.Thanks.
ycp1251887798@gmail.com
I have sent it to you,pls check,I hope you can the
for me,thanks
