Latest firmware for RG500Q-EA and ADB key
i’ve an RG500Q-EA with this firmware: RG500QEAAAR11A07M4G
This is also the output of AT+QADBKEY:
+QADBKEY: 32322549
Is it possible to have latest firmware and key to unlock ADB?
Thanks in advance
hello,here is the passcode, thanks~
Y5zU.E9QRH702z3
Thx!
Is it possible to have latest firmware?
Dear @stich86
I have sent it to you via Message, please check.
i’ve tried but gives me error:
echo -e ‘AT+QADBKEY=“Y5zU.E9QRH702z3”\r\n’ > /dev/ttyUSB3 ; cat /dev/ttyUSB3
ERROR
Use a terminal app, not echo.
I don’t have it :frowning:
no way using echo?
Looks like flashing went wrong, now I’ve the module in bootloop, and running QFirehouse gives me this error:
[038.033]: qusb_noblock_open port_name = /dev/ttyUSB0
[038.033]: 5G module stay in dump mode!
[038.033]: something went wrong???, why only one interface left
[039.034]: poll_wait events=POLLIN msec=1000 timeout
[039.034]: switch to ‘Emergency download mode’
[039.034]: successful, wait module reboot
[045.040]: fail to fopen /sys/bus/usb/devices/4-1/uevent, errno: 2 (No such file or directory)
[046.040]: fail to fopen /sys/bus/usb/devices/4-1/uevent, errno: 2 (No such file or directory)
[047.041]: fail to fopen /sys/bus/usb/devices/4-1/uevent, errno: 2 (No such file or directory)
[048.041]: fail to fopen /sys/bus/usb/devices/4-1/uevent, errno: 2 (No such file or directory)
[049.042]: fail to fopen /sys/bus/usb/devices/4-1/uevent, errno: 2 (No such file or directory)
[050.042]: P: /dev/bus/usb/004/019 idVendor=2c7c idProduct=0800
[050.042]: C: /dev/bus/usb/004/019 bNumInterfaces: 1
[050.042]: I: If#= 0 Alt= 0 #EPs= 2 Cls=ff Sub=ff Prot=10
[050.042]: E: Ad=81 Atr=02 MxPS= 1024 Ivl=0ms
[050.042]: E: Ad=01 Atr=02 MxPS= 1024 Ivl=0ms
[050.042]: tmp=/sys/bus/usb/devices/usb4/../driver, driver=../../../../../../bus/platform/drivers/xhci-hcd
[050.042]: qusb_noblock_open port_name = /dev/ttyUSB0
[050.043]: 5G module stay in dump mode!
[050.043]: something went wrong???, why only one interface left
[051.044]: poll_wait events=POLLIN msec=1000 timeout
[051.044]: switch to ‘Emergency download mode’
[051.044]: successful, wait module reboot
[057.050]: fail to fopen /sys/bus/usb/devices/4-1/uevent, errno: 2 (No such file or directory)
[058.051]: fail to fopen /sys/bus/usb/devices/4-1/uevent, errno: 2 (No such file or directory)
[059.051]: fail to fopen /sys/bus/usb/devices/4-1/uevent, errno: 2 (No such file or directory)
[060.052]: qfirehose.c main 423 fail
Any way to recovery? I don’t have a boot point (EDL exposed.. or not known on this board)
Dear @stich86
Did you check /dev/ttyUSB*?Before upgrade, did the module worked fine?
Is it possible to use -P to configure specified port for upgrading?
yes module was working, now it’s in bootloop..
each time it start then reboot itself
Dear @stich86
It is strange, module in dump mode. which command did you use to upgrade? ./Qfirehose -f and others?
yes ./Qfirehose -f /path/to/firmware
flash went fine each time, but the the module reboot, stay for few seconds on “fastboot” then back to EDL.
No the problem on the last flash is that module seems to go in “dump mode” (in a loop) and no way to put it back in EDL mode (and I don’t have any boot point avaliable).
Any suggestion?
Dear @stich86
Please check if you can pulling up USB_boot to VDD_EXT.
RG500QEAAAR13A01M4G
AT+QADBKEY?
+QADBKEY: 14966991
Thanks in advance
please check the adb passcode, thanks~
WihtftY7/7SWvEd
i’ve an RG500Q-EA with this firmware: RG500QEAAAR13A01M4G
+QADBKEY: 56413442
Thanks in advance
hello, here is the adb passcode, and the latest firmware package, @silvia will support you, thanks~
VxfbdlUnjfUqv6J
Dear @adam15v
RG500QEAAAR13A01M4G is the latest one.
