Hello, we are currently certifying the EG91NAXD with Verizon. Our EG91NAXD are running EG91NAXDGAR07A01M1G_20.004.20.004.
Verizon requires that we demonstrate modem firmware update OTA - is there a newer, or alternate firmware that we could use for this purpose ? Thanks !
hi , Do you want to upgrade the firmware through ota, or do you need to provide a new version for you?
Hi Anna - thanks for the reply. I wanted OTAP update - and only for demonstration (carrier certification). The NA FAE was able to supply delta binaries. Thanks Sean
