Latest firmware for EG25G (EG25GGBR07A08M2G)
Hi all,
I want to update the firmware on one of my modules to the latest one. My problem is that the one with the old FW rev. (V01) doesn’t connect to IMS with IPV6 and I have no VOLTE on that modem. Where in the V02 one, I do have VOLTE.
Here is the FW version of the one I want to upgrade:
ati;+csub;+cversion
EG25
Revision: EG25GGBR07A08M2G
SubEdition: V01
VERSION: EG25GGBR07A08M2G
Sep 24 2021 09:52:53
Authors: QCT
ATI+QGMR
EG25
EG25GGBR07A08M2G_30.004.30.004
Could you please tell me where to find the latest firmware for this one? I would also appreciate a guideline for upgrading the FW. I am planning to use the QFirehose documentation I have (LTE&5G_QFirehose_Linux&Android_User_Guide_V1.1)
PS: I will be using a Linux (Ubuntu) host for the upgrade process. My EG25G is in a 4G LTE pcie housing and connected via USB.
Thanks in advance.
Hi @eg25user.quadified
I send it to you,pls check your chat box.
Could I please also get the release notes for the EG25GGBR07A08M2G firmware
it is possible to have the latest firmware for de EG25-G ?
I have 3 to update
can I get this firmware too? I will be very glad. thank you in advance
I also need this firmware.
Hi, Can I get the latest firmware version as well. As I have EG-25G and it doesnt lock the GPS data. I want to update the firmware and also it will be kind if I can get the latest gpsOneXTRA data file along with some instruction if I have that file on my PC. on how to upload it to the engine?
Hello, I am also interested in the latest firmware for EG25GGBR07A08M2G. I currently have EG25GGBR07A08M2G_01.003.01.003
Also, is it a special firmware for eSIM support on this module? Or it needs some special commands to activate the eSIM support?
Thank you!
Hi @andi.radulescu
I have send the latest firmware to you via chatbox,pls chk.eSIM functionality is supported by default.
Thank you for your reply! My version 01.003.01.003 seems very low compared to the latest one. The version I have does support eSIM by default as well? Since the AT+QESIM commands give me an error on my old version.
Hi, can I request also for the latest firmware. Thanks.
Hi @lyman-Q , can you please send me latest firmware for EG25-G? Thank you.
What is the latest firmware for EG25G? I have EG25GGBR07A08M2G_30.006.30.006
I’d also love to have the latest firmware, if there is a newer one. Currently on EG25GGBR07A08M2G_30.007.30.007
@lyman-Q
Hello, I am also interested in the latest firmware for EG25G because i using Revision: EG25GGCR07A02M1G
EG25GGCR07A02M1G_30.202.30.202
hi , i got it but i need latest with documents
The firmware file already contains RN
