Latest firmware for EG18-EA
Hello everyone, I need help with the firmware for the module EG18EA. I currently have the EG18EAPAR01A08M4G version, what is the latest one and where can I download it?
Thank you in advance.
Is this for Europe version right? I need to flash it in a zyxel 4G modem.
Can you send me also the firmware to downgrade to the EG18EAPAR01A08M4G version in case of problem?
Thank you very much.
I can’t find the corresponding firmware version EG18EAPAR01A08M4G
I think the EG18EAPAR01A11M4G version would be okay too. Can you send the DFOTA to upgrade from 11 and downgrade from 13 to 11?
Thank you.
I’d like this too please. Thanks
Send me the latest firmware version too, my modem keeps losing connection, firmware version 12
I have problem with modem in Mikrotik LHG (No response for AT E0 V1) I Have USB 3.0 to M2 adapter and QFLASh. Plase send me latest firmware for eg18-EA
Good evening,
I will have soon a Mikrotik LHG LTE18 with your modem module, I am looking for the last firmware, you already sent me the Rev. EG18-EA-PA_Firmware_Release_Notes_V0113_01.201.01.201 Date: 2024-08-28 some time ago.
Could you send me the last firmware, QFlash and if possible the EG18 AT command manual?
Thanks in advance
I have sent them to your email,pls check your email.
Got the package, thank you so much!
Hi.
My Mikrotik says there is a new firmware but can´t get it.
 model: EG18-EA
revision: EG18EAPAR01A13M4G
imei: 869816041505545
Cab you please send it to me?
Thank you so mutch!
I have sent the latest firmware to your email, pls check
Dear Quectel Support,
I would like to request the firmware EG18EAPAR01A13M4G_01.201.01.201 for my Quectel EG18-EA module.
Module information:
  • Model: EG18-EA
  • Current firmware: EG18EAPAR01A13M4G
  • IMEI: 869816043793255
The modem is installed in a MikroTik ATL LTE18 kit.
After updating the modem firmware, it is no longer able to register on Russian mobile networks (MCC 250). The SIM cards work correctly in other devices, but the modem cannot connect to any Russian mobile operator.
According to reports from other users, firmware version EG18EAPAR01A13M4G_01.201.01.201 resolves this issue. Could you please provide this firmware package, or, if a newer firmware is available that fixes the registration issue in Russian networks, please provide that version instead.
If required, I would also appreciate receiving the appropriate QFlash/QFirehose tools and any flashing instructions.
Thank you very much for your support.
Best regards
I have sent them to your email, pls check
I have an EG18-EA module in a MikroTik router. After updating to firmware 01.300.01.300, the module cannot register on any network in Russia (MCC 250). AT+CEREG? returns +CEREG: 0,4 (“registration denied”).
I installed the suggested firmware 01.201.01.201, but the issue remains. The module sees available networks but cannot register.
Could you please provide a working firmware version that resolves this problem? I am also ready to test any beta version.
I have a Zyxel LTE7490 router with an EG18EAPAR01A08M4G module; would it be possible to get the latest firmware version? Thank you in advance.
