Latest firmware for EC25-AF?
Also having problems to connect to AT&T, like others mentioned here on the forum already, I am using EC25AFFAR07A08M4G . If this is not latest firmware, please state, which is latest version, and pls, email.
I have to state here, that I am very unhappy with Quectels policy regarding modem firmwares. It would be a good idea, to publish list of most recent firmware versions, at least. Current policy, in combo with often slow response from support, does not encourage usage of Quectels modems.
Hi @speibl
Please allow me to apologize, sorry for the bad experience, please can you give me your email, I will send you the latest firmware, you are not currently using the latest firmware.
Best Regards
Lyman
Pls, mail to
augustus_meyer@yahoo.de
Thank you.
Hi @speibl
I send the firmware to you,please check.
Thank you, I got it. BTW: Is there some kind of change log available, to track the bug fixes / changes in the various versions ?
Hi @speibl
Yes, there is a release note document in the firmware package with what was fixed in each version.
Thank you, I got it. Because my EC25-AF is built into a router, running openwrt, I need to ask, how to use the file, you sent, with
qmi-firmware-update ?
The USB port of the device is not led out, right?
Sorry, I have no idea. The device in question is a Teltonika RUT955, running “official” openwrt firmware. You might find tech specs on their site.
It might be a good idea, to provide a software package regarding firmware update for openwrt, in casing of using special tool(s), because your modems are used quite often. However, maintaining a fleet of them needs a stable firmware foundation. And buying more devices over time often shows various firmware versions for the modems, which is a PITA to keep in sync.
Can you please mail the latest firmware to me for EC25-AF?
EC25-AF(D)
Revision: EC25AFFDR07A08M4G
Hi @vidplace7
I have send it to you by chatbox,pls chk.
I’m sorry for bothering but I was wondering if you could share the latest firmware with myself as well.
I too would like the latest firmware for the EC25-AF
Thank you
can you also send the latest firmware to me? thank you. i still have: EC25AFFAR07A08M4G_01.001.01.001
I have firmware EC25AFFAR07A14M4G_01.003.01.003
Is this the latest ? If not please email latest version. Thank you.
Hi @speibl
Yes it is.
Pls send me latest version for EC25-AF
Currently, we have an issue where the APN for AT&T keeps resetting. We need a version where this doesn’t happen. Right now, we’re using version EC25AFFDR07A09M4G_01.004.01.004.
a.duniushkin@motionray.tv
Also, send the firmware for EC25-AF to me! vasily@done.co.il. We got this modems inside GPS trackers, and some of the, lost connectivity with local providers.
Why is this process so strange? Can these firmware files not be hosted on a server somewhere?
I’m having this same issue. Currently on firmware version EC25AFFDR07A09M4G_01.004.01.004
I notice that one of my working devices has firmware version EC25AFFDR07A10M4G_01.003.01.003
Could you please send me the latest firmware (or at least version EC25AFFDR07A10M4G_01.003.01.003)
Also, is there a way to backup the firmware currently installed on the modem?
