Request on latest firmware.
Thank you.
Latest firmware for EC200A-AU Current version: EC200AAUABR02A05M2G_OCPU_01.001.01.001
Thank you.
Hi @Marlene_Munoz
could you confirm the project is quecopen or standard AT command module? from the FW you mentioned, it is Quecopen solution.
Open software is updated according to specific requirements. The version provided to customers is generally the official release, and customers carry out development based on this version. Upgrades are only performed when the SDK fails to meet customer needs, or when we have platform update requirements and recommend that customers upgrade.
Hello Support,
I currently have the QuecOpen version, but I would like the standard AT command version—specifically one that includes the MQTT AT commands mentioned in the modem family datasheet (I am working on a small project).
Response to ‘ATI’:
EC200A-AUAB
Revision: EC200AAUABR02A05M2G_OCPU
Thank you very much for your help.
Hi @Marlene_Munoz
For this specific variant (EC200AAUAB) we do not have standard FW version. this variant only support in Quecopen solution. EC200AAUABR02A05M2G_OCPU is the latest FW version.
Another question:
Would it be possible to make a change—replacing the module with the EC200AAUHA—while keeping the same shield (board/carrier)?
I believe the physical pads are the same.
Thanks.
Hi @Marlene_Munoz
Since EC200AAUAB are in open solution. some pins are not compatible with the standard module with EC200AAUHA. open solution has some GPIO pins while standard module do not have it.
