Latest Firmware BG95-M3
@Felix.feng-Q Felix: Please help to follow up and handle this matter. thank you.
CC: @Evral @herbert.pan-Q
I have submitted the delta application. Please wait.
I have sent the delta package to your email, pls check
hi, Evral
BG95 does not currently support these two interfaces. I will check with our internal team to confirm compatibility.
I’ve double-checked with internal teams. AGPS and APFLASH are enabled by default, and no special configuration is required on the APP side.
May you send the latest firmware for the Europe region please. BG95M3LAR02A03_01.016.00.000 seems not working to get a service.
@Felix.feng-Q any update for the firmware?
Please send me the latest standard AT firmware for BG95-M3
Please provide your current firmware version or IMEI
The version is BG95M3LAR02A03.
Hello, could you please provide:
The latest firmware available for the BG95-M3.
The latest firmware that supports eSIM (eUICC) profile management AT commands.
My current firmware version is:
BG95M3LAR02A03_A0.206.A0.206
I do not have access to the USB/DM flashing interface. Since the update will be performed via DFOTA, I need the corresponding delta packages from my current firmware version to both firmware releases.
My email: sarp.mertol@sglsystem.com
I have sent the latest firmware to your email, pls check and try
Hi Quectel!
I have firmware: BG95M3LAR02A03_01.011.01.011
Can you please send me latest (DFOTA, and full please)
Thank you very much!
