Latest Firmware BG95-M3
Please send me the full firmware package for the BG95-M3. My current version has MQTT AT commands disabled.
>>> AT+QGMR
BG95M3LAR02A03_31.202.31.202
>>> AT+QMTCFG=?
ERROR
>>> AT+QMTOPEN=?
ERROR
Please send me the full standard firmware, which I think might be BG95M3LAR02A03_A0.303.A0.303.
Can you email the firmware to me, and also confirm that the MQTT AT commands should work?
I have sent the latest firmware to your email,pls check, and MQTT is supported for BG95
Please send me the full firmware package for the BG95-M3,too. I have some problems to activate esim support.
Could you send me the latest firmware version for BG95-M3, please?
My firmware:
BG95M3LAR02A04_01.200.01.200
My email: dzakrzewski@common.pl
Please send me the full firmware package for the BG95-M3. I’ve updated my BG95-M3 to firmware BG95M3LAR02A03_31.202.31.202, but the Python version is still outdated, 3.4.0. I need a package like QPY_OCPU_BG95M3_XXXX_FULL, Can you send it to me? Thank you
Can you send me the latest version of firmware for BG95-M3? I download the latest version from Resources Download | QuecDevZone but the latest version is from 2024, I found that some API methods is missing, e.g.: quecgnss.configSet
Is there any sense to update firmware download page and put a new version here?
Hi! Can you please send me this full firmware version for BG95M3?
BG95M3LAR02A03_01.200.01.200
Thanks!
My current firmware is BG95M3LAR02A03_01.011.01.011
Can you please send me both a DFOTA and a full update to the most stable version available?
Thank you very much!
I have sent the latest one to your email, pls check and try again
Please provide the version of your current firmware.
BG95M3LAR02A03_OCPU_QPY is sent to your email, pls check
we have BG95M3LAR02A03 and BG95M3LAR02A04 connected with a ST ESIM chip (ST4SIM200) or (ST4SIM300). we need to switch/configure the esim profiles via CCIS/PCSC.
The current firmware doesn’t support that.
Can you help us?
Thank you! I also need the delta DFOTA file to upgrade from BG95M3LAR02A03_01.011.01.011, is this included in the ZIP file you sent me? If so, what is the name of the DFOTA file?
If not, can you please generate me a DFOTA to upgrade from BG95M3LAR02A03_01.011.01.011 to the latest?
Thank you very much and have a great day!
Also can you confirm that the firmware you sent me (BG95M3LAR02A03_A0.303.A0.303) is correct for USA ? I should have specified that.
Thank you!
Dear Quectel Support Team,
I am currently developing an IoT fleet tracking solution using the BG95-M3 module with QuecPython.
My current firmware version is : BG95M3LAR02A03_31.202.31.202
I noticed that the quecgnss.configSet() and quecgnss.configGet() methods are not available in this build, while they are documented in the QuecPython API reference (developer.quectel.com). These methods are essential for enabling AGPS (config_type=2) and APFLASH (config_type=3) in order to improve the GNSS Time To First Fix (TTFF).
Could you please provide me with :
  1. The latest QuecPython firmware for BG95-M3 that includes quecgnss.configSet / quecgnss.configGet support
  2. The corresponding flashing instructions (QPYcom or QFlash)
Module details :
  • Model : BG95-M3
  • Revision : BG95M3LAR02A03
  • Current firmware : BG95M3LAR02A03_31.202.31.202
  • Application : QuecPython fleet tracking (IoT)
774975099 / evraldimba@gmail.com**
Yes, it is applicable.
@Grey.Tu-Q Grey, please help me solve the case.
