Latest Firmware BG95-M3
I have sent the latest firmware to you,pls check
Thank you very much!
Thank you. I will check it!
Could you please provide the newest stable version firmware for BG95M3LAR04?
I’d like to try to upgrade BG95M3LAR02 to BG95M3LAR04 by QFLASH upgrade tool.
R02 to R04 are not permitted. They cross the baseline version and may pose potential risks.
I need a BG95M3LAR04 for VoLTE testing. What should I do?
Thank you in advance.
I have sent it to you, but R04 is only used for testing.
Hi Herbert,
I have the Zero Development Board. It seems that the Zero Development Board can only support QPY Firmware but QPY firmware (BG95M3LAR02A03_31.201.31.201). But this QPY firmware doesn’t support AT commands for MQTT. I want a stable firmware that support Zero Development Board and also AT commands for MQTT. Could you please share me with such firmware?
Dear Herbert, I tried the firmware you sent. I use Qflash to flash the \upudate\firehose into the zero development board. I can flash the firmware into BG95-M3 Zero development board. However, the board reboot itself every second and I can use such firmware. Please advise. Thanks.
Please provide photos of the development board during the debugging process.
My firmware is BG95M3LAR02A03 and have problems with DNS. Can I get a delta firmware for DFOTA update?
Please provide the version of your current firmware.
AT+QGMR
The current firmware is:
AT+QGMR
BG95M3LAR02A03_01.200.01.200
Could you please provide me with the last stable version?
Hi exactly the same question for me, could you provide me with latest stable version (preferably fully supporting QMI):
AT+QGMR
ATI
BG95-M3
Revision: BG95M3LAR02A03
Hello! I have the bg95-m3 and i need support for eSIM commands to manage profiles on my esim, as i understand it now i have support to use an esim, but not manage it with AT+QESIM etc.
AT+QGMR
BG95M3LAR02A03_01.204.01.204
is there a later version supporting ESIM?
please resend me the firmware files, the previous link has expired
