Latest Firmware BG95-M3
Hello Herbert,
thanks for the new firmware, but I have one question:
I currently have BG95M3LAR02A03_01.200.01.200 and you sent BG95M3LAR02A03_A0.206.A0.206.
Further above in this post I can see there’s also a BG95M3LAR02A04_01.001.01.001 version available (LAR02A03 vs. LAR02A04).
Can you please explain the difference ?
Best regards,
lakeroe
@herbert.pan-Q Can you please send me the latest firmware for the BG95-M3 modem?
We are also working on a test PCB with BG95-M1, so the firmware for this would also be good. Thanks!
@herbert.pan-Q Can you please send me the latest firmware aswell? thanks :slight_smile:
@herbert.pan-Q, would you please send me the latest standard firmware for the BG95-M3? Thanks.
I have sent the latest firmware to your email,if your current firmware version is A04,pls use A04 package,pls check, I hope you can click the :yellow_heart: for me,thx
Hey @herbert.pan-Q !
We’re using a bg95-m3 module on our own pcb which is behaving differently than our bg95-m3 on our eval kit. To find out if this difference is due to a hardware or firmware issue I kindly ask you if you could send us the version:
BG95M3LAR02A03_01.200.01.200 as well as the latest version. Thanks!
Hi @herbert.pan-Q ,
I see you have been very helpful, can I please get the BG95M3LAR02A03_01.200.01.200
file? I currently have BG95M3LAR02A03_01.009.01.009
thank you!
Can you please send me the latest firmware for BG95-M3? thank you.
Hi Sir,
May i ask your current firmware version? Thx a lot
I have sent them to your email,pls check, I hope you can click the :yellow_heart: for me,thx
I have sent it to your email,pls check, I hope you can click the :yellow_heart: for me,thx
the firmware version is G95M3LAR02A03_01.009.01.009
Dear @herbert.pan-Q ,
Thank you very much. Can you please also send me the DFOTA image for updating from BG95M3LAR02A03_01.200.01.200 to BG95M3LAR02A03_A0.206.A0.206.
Thank you!
any update for the firmware?
hi @ert
I will check and reply via email if i get the firmware version. Much appreciation.
Could you please send the latest firmware upgrade which is used for the RED DA?
I currently have BG95M3LAR02A03_01.014.01.014
Thank you in advance
Could I too get the latest firmware upgrade from version BG95M3LAR02A03_01.014.01.014? Thanks
Hi @Alex_Palumbo
I will check and reply when i get the necessary firmware. Much appreciation.
I have 2 modules labeled as
BG95-M3-TE-A Q1-A5440-BL320369
BG95M3LATEA-64-SGNS
Their SNs:
Module 1:MPC23D62A000103
Module 2:MPC23D62A000121
Output of respective AT commands:
[2025-04-15 14:08:41:468_R:] ATI
[2025-04-15 14:08:41:468_R:] Quectel
[2025-04-15 14:08:41:468_R:] BG95-M3
[2025-04-15 14:08:41:468_R:] Revision: BG95M3LAR02A04
[2025-04-15 14:08:41:468_R:] OK
[2025-04-15 14:08:51:287_R:] AT+CVERSION
[2025-04-15 14:08:51:287_R:] VERSION: BG95M3LAR02A04
[2025-04-15 14:08:51:287_R:] Jul 16 2024 18:05:42
[2025-04-15 14:08:51:287_R:] Authors: Quectel
[2025-04-15 14:08:51:287_R:] OK
[2025-04-15 14:08:59:960_R:] AT+QGMR
[2025-04-15 14:08:59:960_R:] BG95M3LAR02A04_A0.206.A0.206
[2025-04-15 14:08:59:960_R:] OK
Can you please provide me the firmware we can upgrade modules to for supporting VoLTE (Voice Calls over LTE network). With current FW VoLTE doesn’t work.
eMail: dusan.kikovic@gmail.com
or
dusan.kikovic@a1.at
BR
Dusan.
Hi @herbert.pan-Q ,
file? I currently have BG95M3LAR02A03_01.009.01.009. The file you sent me before did not contain any usable.bin files. Thank you.
