Latest Firmware BG95-M3
I have sent it to your email,pls check, I hope you can click the :yellow_heart: for me,thx
Thank you very much for answer. Version you sent me seems exactelly the same as currently deployed on modules. We need SW version supporting VoLTE.
Jonathan.wang wrote me on 16.04: ‘R02 version does not support VOLTE. If you need VOLTE feature, the R04 version will support. However, it is not suggested to upgrade from R02 to R04 since it will cause failure.’
Our current version: AT+QGMR: BG95M3LAR02A04_A0.206.A0.206
Version you sent me (according to file name and Rel. notes): AT+QGMR: BG95M3LAR02A04_A0.206.A0.206
We need either target version supporting VoLTE from our current version or intermediate version to upgrade from current and in next step to upgrade to target version (R04). Can you please check and propose solution for us, how to come from version BG95M3LAR02A04_A0.206.A0.206 to the one supporting VoLTE.
Thank you
BR
Dusan.
Hi @herbert.pan-Q,
I am unable to find any usable .bin files in the zip files you have sent me. Can you please just send me the .bin file for BG95M3LAR02A03_01.200.01.200?
Thank you
pls select the file BG95xxxxxxx\update\firehose\partition.mbn
Do you have an update regarding this topic?
BR
Dusan.
Hello @herbert.pan-Q
Can I get access to the most recent firmware which provides access to QuecDevZone ?
Can you send me the latest firmware? I currently have BG95M3LAR02A03_A0.206.A0.206.
Hi I need a FW for BG95M3LAR02A03 that suport eSIM/LPA, is possible?
Thank you
Rui
Great thank you, now I have some Quectels with the older firmware BG950AGLAAR01A03_01.201.01.201.
Do you know if there is a major difference?
Also i would like to be able to update them. Could you send me the latest firmware BG950AGLAAR01A03_01.203.01.203?
I see a difference in behave of time reporting using QNTP between this firmware:
BG95M3LAR02A03_01.014.01.014: AT+QNTP would return GMT time
BG95M3LAR02A03_01.204.01.204: AT+QNTP would return local time
is there any reasons for that?
regards,
Charles
The version that supports eSIM needs to be customized and you need to apply to Quectel
I have sent the BG950AGLAAR01A03_01.204.01.204 to you, pls check
Could you provide the relevant logs?
Hi, where do you have sent it? I have checked my mail inboxes and my Inbox here at quectel.
I have a module with this firmware version:
BG95M3LAR02A03_01.011.01.011
Please send me the latest build.
@herbert.pan-Q @leon.bao Could I get the firmware I requested above please?
Hi,@WiFiLuke
I have sent to you via email,pls check
I received the file, thank you!
