i need EPAT tool grater then version EPAT_V1.3.99.165 to capture log of bc660k-gl firmware version BC660KGLAAR01A05_01.200.01.200 log
I have sent it to you
I am using BC660 and having trouble with login to AWS MQTT using SSL and custom authorizer. Can I have access to the EPAT tool to help with debug?
Thank you very much!
Sam
Thank you again for access to the tool. One additional request, I need the databased to update for BC660:
2024-06-12_07:03:49:508]ATI
[2024-06-12_07:03:49:508]Quectel_Ltd
[2024-06-12_07:03:49:508]Quectel_BC660K-GL
[2024-06-12_07:03:49:508]Revision: BC660KGLAAR01A05
Is it possible that you can provide to me?
Thank you,
Sam
Hello @herbert.pan-Q would you like to send me EPAT tool and db for BC660KGLAAR01A05_01.203.01.203? Thank you from advance! My email is dkubeczek@aiut.com
Thank you @herbert.pan-Q , but got problems with verification code from office365 - could you send this package to mi directly please?
I have sent it to you by my email
Hi @herbert.pan-Q ,
Can you send EPAT download link to me on hardik@shipmentia.com
Hi @herbert.pan-Q ,
I would like to request the EPAT tool as well, is requesting here the correct place to ask for it?
Many thanks,
Steve
I also require the EPAT download link please.
I have sent it to you,pls check,I hope you can click the
for me, thanks
Thank you Herbert.pan
I have EPAT working fine.
For me to update the database, (so I see less hex and more useful information) where do I get the updated txt files please?
My Modules are BC660K-GL AAR01A05
If you need further specific model identification, please give me the AT command for me to get it.
The EPAT I have is Version 1.3.137.236 (PC Ver 0x65084851)
Thank you again for your help. ![]()
Regards,
Steve
I have sent it to you,The parsed DB file is in the firmware file,pls check,I hope you can click the
for me, thanks
Perfect, all the Hex is decoded now.
Thank you for all your help again!
