Hello, for linux I need the following drivers:
For windows instead, please share the following:
Which Quectel modem do you use?
I have the RM502Q-AE and the EM160R-GL-AU
I will send it. Please check the message later.
I’m trying to access the ADB interface on my EM160R-GL, since I need to change the default IP it has (192.168.225.1) what are the AT commands to do that?
I think you have modified the settngs.
AT+QCFG=“usbnet”
By default it is 2.
If would like to get IP from the gNodeB, please set the usbnet to 0 or 2.
And if you insist on the usbnet mode you are using now, you need find the /etc/mobileap_cfg.xml.
Or you can check whether it support AT+QCFG=“lanip”.
Can you explain me the steps to access the /etc/ folder and the XML files within? Is there a password to enter to access ADB?
Q: Is there a password to enter to access ADB?
A:hello, for adb password, i will send to you, please give me your quectel-ID,
another question, bean will continue to help you ,thanks~
